1.6 engine conversion
Posted: Sat Sep 01, 2012 6:33 pm
by dunnin21
I have to 8v single point injection vitara engine. I think that I need the low pressure fuel pump. 1.5 -4 psi is this correct. Thanks
Re: 1.6 engine conversion
Posted: Sat Sep 01, 2012 7:07 pm
by Darrell
Injection systems use a high pressure pump to operate. These are normally fitted inside the fuel tank - number 2.
- vit fuel pump.gif (29.55 KiB) Viewed 4350 times
Or are you going to convert it to carb. If so then yes I believe that pressure range is fine.
Posted: Sat Sep 01, 2012 9:09 pm
by dunnin21
no im leaving it as injection. can any1 tell me what psi rated pump i shall need
