Anyone running potty springs from llama 4x4?
Posted: Fri Jul 13, 2012 3:44 pm
by chrisj410
Been running Adda leafs and love the improvement I've got from them, I'm guessing these would feel even better anyone running them?
Cheers Chris
Re: Anyone running potty springs from llama 4x4?
Posted: Fri Jul 13, 2012 11:24 pm
by ferris
I'v got a set. Went for the 2.5inch lift and had the top leaf made slightly thicker so they would last longer. The ride was ok with them, better than add-a-leafs but you can't expect to much from SJ springs.
They started to lean to the drivers side quite quickley. This is quite common on SJ's anyway, but i think it was made worse as i didn't have the u bolts tight enough and it was causing axle wrap. So can't blame the springs entirely.
