Page 1 of 11
Jay's SJ410 VBJA now sold :(
Posted: Sat Jun 30, 2012 4:20 pm
by Jay18
So i thought it was about time i done a build thread on my SJ so here goes...
this is on the day i got the car 26/06/2010 (pics are bad quality as the phone i used was rubbish!)
cant seem to get the pics closer but you get the idea...
so work began...
first thing i got was a tin of black hammerite so the painting began...
all the under side of the car was cleaned and i painted all of the bottom of the car and chassis..
then i bought a nice new pair or front springs...
i treated the car with a set of standard size vitara wheels...
And then i had an idea, since the Suzuki SJ is well know for falling over i thought some 3" arches would go well with a set of vitara wideboy wheels...
i used two trailor arches cut down the middle and welded onto the car after cutting all the rust out but because of the amount of rust that was cut out i had to buy some sheet steel and patch up the gaps, then when cleaned and filled it looked great, here are the pics....
after all the welding was finished i undersealed all of the floor inside and out..
Re: SJ410 VBJA Wideboy
Posted: Sat Jun 30, 2012 5:02 pm
by Jay18
i tinted the rear window myself aswel..
after all the hard work here is how she looks now...
With the pajero seats fitted with custom seat rails..
bull bar fitted:
i am currently doing the rear springs, after taking nearly a whole day doing just one spring as i had to hack saw a bolt off to remove the spring and then had to walk 2 miles from my nans house where the car is kept back to my house to get a bolt for a replacement and then walked back up there...
so tomorrow hopefully i wil get the other spring fitted.....
Posted: Sat Jun 30, 2012 6:44 pm
by Darrell
Well done for rescuing her. Thats quite a bit of rust you've cut out there :thumbup:
Those springs are normally a pain in the ar*e. Chucked grease all over mine but the buggers still rusted together :argh:
http://suzukiclubuk.co.uk/forum1/viewto ... 15/t,3717/
Posted: Sat Jun 30, 2012 7:07 pm
by Jay18
looks like we had the same problem, the spring mount bolt wouldnt come out of mine so i had to cut it out with a hacksaw then i found that the bolt had rusted and expanded so i couldnt pull it out so i had to get a new bolt from home to replace it, think im going to have to do the same thing the other side but ive got a second bolt so im prepared, this has been a big project mainly taking alot of time since im unemployed and just finished college aswel but its getting close to the M.O.T...
Posted: Sat Jun 30, 2012 8:17 pm
by b6mfd
Makes me a feel a little better :) that's a lot of work youv done!
Posted: Sun Jul 01, 2012 10:35 am
by Edweird
That wheel-arch job is the dogs unmentionables! You had huge holes to fill and yet the outside is smoother than....a very smooth thing.
Posted: Sun Jul 01, 2012 6:17 pm
by Jay18
thanks guys! it has took a lot of work to get to where it is now, just little bits to get a mot now and i did spend weeks and weeks on filling and sanding to get a good finish, just need a few more coats of paint and it should look very clean and smooth...
Posted: Sun Jul 01, 2012 7:41 pm
by Tramp
very nice looking, I like how you've added the box section to your sills to mate your extended wheel arches together it almost looks standard but loads more functional!
Great job!
Posted: Sun Jul 01, 2012 8:09 pm
by Jay18
thanks! when we finished the arches i thought it looked a bit wierd then i found some 3" by 2" box and it fitted perfectly to the width of the arches and works great as a side step, after standing on it and finding its completely solid i then thought id test the arches and i can bounce up and down on all 4 arches and the dont move at all so it is all very strong :)...
Posted: Sun Jul 01, 2012 8:43 pm
Nice work, came out real good. :guns:
I do have to admit I still think you should trim the front of the front arches up to the bottom of the front wings though. It will look a lot cleaner I think.
