my build
OllieSJ
my build
Post by OllieSJ » Wed May 30, 2012 11:19 am
Going to start my tin top build friday night and going to try to put her back on the road atm she is fully standered with alloy wheels . Does anyone know why my engin does tick over you have to have acceloretro down or choke on !! Help thanks (pics to come friday)
Highlander
Re: my build
Post by Highlander » Wed May 30, 2012 12:00 pm
Do you mean your engine doesn't tick over?
Does it stall without the choke?
could be plugs/points/timing/dizzy cap/HT leads/plugs/air leak/mixture screw on carb
or maybe it just needs the throttle cable adjusted at the carb
OllieSJ
Re: my build
Post by OllieSJ » Wed May 30, 2012 8:32 pm
the engine doesn't tick over
dazerede
Re: my build
Post by dazerede » Wed May 30, 2012 8:37 pm
have you adjusted the choke on the carb with a flat screwdriver that might be the reason or not
4” calmini lift kit :)
Re: my build
Post by dan_2k_uk » Wed May 30, 2012 8:53 pm
What engine and what carb?
OllieSJ
Re: my build
Post by OllieSJ » Thu May 31, 2012 9:44 am
1.3 with standerd carb but going to clean it up but would be great to get the engin working i dont know how to egust the choke carb thing could you explain please
Re: my build
Post by twiss » Thu May 31, 2012 11:06 am
Eesh standard carb... its probably shot... the chokes break and get jammed really easily on the standard aisin carbs
Might be worth taking the choke plate out and seeing how it runs... if you take the chamber off the top of the carb you can see the choke plate at the top. there should be 2 screws holding it on.
If you undo them though, for the love of god don't drop them down into the carb!!!
OllieSJ
Re: my build
Post by OllieSJ » Thu May 31, 2012 5:16 pm
yer m8 just to say don't know if it effects it but its been changed to manual choke
Re: my build
Post by twiss » Fri Jun 01, 2012 8:42 am
ahhhh ok then... probably not that then
