spring over axle
Posted: Mon May 28, 2012 9:58 pm
by adamsj
Wen u do spring over axle do u have to angle the axle upwards more.if that makes sense
Re: spring over axle
Posted: Tue May 29, 2012 9:41 am
No! This is a common mistake people make.
It destroys the caster angle on the front axle.
On the rear UJs on the propshaft will no longer be in phase and will fail prematurely.
Weld the new SPOA perches on parallel to the existing SPUA perches.
Posted: Tue May 29, 2012 9:47 am
by Highlander
Angle the diff upwards to reduce the angle on the prop/ujs?
No, especially not on the front, it'll throw your steering geometry out.
Posted: Tue May 29, 2012 10:29 am
by ROBBIE
dont do sprig over nasty mod imo
Posted: Tue May 29, 2012 10:47 am
by Highlander
Great ground clearance for off road though
Posted: Tue May 29, 2012 3:24 pm
by adamsj
Cheers.that mite b why the axles that r on it r nakerd
