HEAT!!!
Posted: Fri May 25, 2012 1:58 pm
by suzukisteve
Cant take it anymore the doors are coming off!! :doublethumbs:
Re: HEAT!!!
Posted: Fri May 25, 2012 2:37 pm
by OllieSJ
good shout my roof is going to be down this weekend and windscreen down door off !!!
Re: HEAT!!!
Posted: Fri May 25, 2012 2:43 pm
by turbo-tom
good luck taking your doors off , dont use a screw driver because the will snap instantly , best way i belive is chip off all the paint aroudn the screw the hit a shitty flat head screw driver in the slot at angle and follow the screw around as you go ;) if that makes any sence :lol:
Re: HEAT!!!
Posted: Fri May 25, 2012 2:49 pm
by Highlander
I make a nice big slot in them with a thin cutting disc in an angle grinder then gently use an impact screwdriver on them :hahaha:
Don't hit them too hard or you'll bend the bodywork :hahaha:
Re: HEAT!!!
Posted: Fri May 25, 2012 2:57 pm
by suzukisteve
as it goes, just as winter was ending, i had a cunning plan... more cunning than a fox.. who had just graduated head of cunning from oxford university!
I GOT THE GRINDER OUT!! :rockin: lol
i cut the tops of the hinges off so i can just lift the doors off! :guns:
Re: HEAT!!!
Posted: Fri May 25, 2012 3:09 pm
by Highlander
But why??
these billet ones are only $239!! :hahaha:
http://www.zuk-n-ovations.com/pages/bod ... inges.html
Re: HEAT!!!
Posted: Fri May 25, 2012 3:16 pm
by suzukisteve
f*ck me! why didnt i go for those? :hahaha:
half hour with a grinder and a splash of hammerite, job done!! :thumbup:
Re: HEAT!!!
Posted: Fri May 25, 2012 4:16 pm
Just don't forget to make sure you have at least 2 rear view mirrors otherwise mr plod wont be happy!
Re: HEAT!!!
Posted: Fri May 25, 2012 4:38 pm
by suzukisteve
well one of mine has fallen off anyways lol. :roll:
but no i do need some, was thinkin bout mounting some motorbike ones on the wing or something..
Re: HEAT!!!
Posted: Fri May 25, 2012 4:41 pm
by suzukisteve
