snorkel Help
Posted: Sat May 12, 2012 7:55 pm
by dunnin21
HI guys, im going to knock a snorkel up on the cheap out off sum 68mm plastic drainpipe and a air filter. the question is i need some sort of pipe around 70mm dia, to go from the bottom of the solid plastic tube to the airbox. Dose anyone have any suggestions on what i could use i have looked on net and ebay and running out of idears. Thanks andy
Re: snorkel Help
Posted: Sat May 12, 2012 8:01 pm
by trotter
try hardware stores for some flexi hose B&Q HOMEBASE WICKES etc doesn't matter what it is so long as its watertight and fits :thumbup:
Re: snorkel Help
Posted: Sat May 12, 2012 8:58 pm
by Darrell
Found this http://www.demon-tweeks.co.uk/motorspor ... -ducting-2 if you can't find anything local.
Re: snorkel Help
Posted: Sat May 12, 2012 9:28 pm
by dunnin21
ill try bq some were like that do you guys round it up O/S or N/S
Re: snorkel Help
Posted: Sat May 12, 2012 10:46 pm
by trotter
depending where you airbox/carb is i'd run it from there.
eg. my carb is drivers side so i'd run one straight out through edge of bonnet/wing and up where the aerial is
Re: snorkel Help
Posted: Sun May 13, 2012 10:38 am
by chrisj410
Steal the pipe off of the mrs Hoover, I made one on my samurai got my pipe from machine mart
Re: snorkel Help
Posted: Sun May 13, 2012 10:08 pm
by dunnin21
chrisj410 wrote:Steal the pipe off of the mrs Hoover, I made one on my samurai got my pipe from machine mart
was it 70mm
