lifting kits
Posted: Wed Apr 25, 2012 10:46 am
by phil1511
hello i have had a look to see if anyone as asked this before but i couldnt find anything what is the best way to lift my suzuki sj413 from what i have gathered just lifting shakles are no good so do i need to buy a proper lift kit some thing like this one ?
http://www.google.co.uk/imgres?q=suzuki ... =151&ty=70
Re: lifting kits
Posted: Thu Apr 26, 2012 12:36 pm
That is a lot of money for a 3" spring lift
I think you could do it cheaper
Llama4x4 4x
potty leaf springs £430
polybushes £49.50
new U-bolts £52.80
shocks £168
extended brake lines £40-50 (also not included in that kit) total so far = £750.30
drop pitman arm £100ish but you can get away without running one up to about 2.5" lift. thats £850 so nearly £80 cheaper so far including the drop pitman arm.
Then you can easily make lowered bumpstops yourself with some 2" box section and a drill, if you're offroading your SJ you'll also want to remove the anti roll bar as it limits flex so no need for drop brackets for that.
Re: lifting kits
Posted: Fri Apr 27, 2012 2:44 pm
by phil1511
ok thanks for the help
Re: lifting kits
Posted: Fri Apr 27, 2012 2:47 pm
by phil1511
just a thought could i not just put 2 inch blocks on the origional dampers save me having to buy them to?
Re: lifting kits
Posted: Fri Apr 27, 2012 3:07 pm
Yes you could get away with that, however it might limit your droop articulation depending on how well the springs flex, I would advise, fitting the springs, then flex it up to the point a tyre lifts with no shocks on. Then measure between all the shock mounts to get the lengths right on the new shocks if they are needed. When you do this you want to flex it up on both a front and rear tyre then use the biggest measurements as you might find the suspension flexes more when a rear wheel is jacked up than when a front is if that makes sense.
Re: lifting kits
Posted: Fri Apr 27, 2012 3:12 pm
by phil1511
yer i get what u mean do u no were to get all the stuff (liftkit)?
Re: lifting kits
Posted: Fri Apr 27, 2012 3:30 pm
yep
ScottieJ wrote:
www.Llama4x4.co.uk
polybushes £49.50
new U-bolts £52.80
shocks £168
Or If you wanted a better ride and more articulation you could always look in to a Wrangler YJ spring swap like Myself, Ferris and Trotter
![;) ;)](./images/smilies/icon_wink.gif)
YJ springs can be hard to source though.
http://forum.suzukiclubuk.co.uk/vi ... start,170/
Or there is the option of running rear springs up front and bedford rascal springs on the rear, this gives you aboutr 1.5-2" lift.
