cherry bomb
Posted: Wed Apr 11, 2012 7:56 pm
by dazerede
i would like to get a cherry bomb exhaust but cant find and inlet small enough to fit on my 410 sj my inlet it roughly 30mm yes i now pee shooter and the smallest inlet i can find on a cherry bomb is 38mm would it be alright to modify it a bit
Click Here for Ebay Listing
Re: cherry bomb
Posted: Wed Apr 11, 2012 8:00 pm
by dan_2k_uk
I just scaled mine down with a few other bits i had untill it was the right size by the time it got to the flange in the middle of the system.
Dan
Re: cherry bomb
Posted: Wed Apr 11, 2012 8:01 pm
by turbo-tom
dazerede wrote:i would like to get a cherry bomb exhaust but cant find and inlet small enough to fit on my 410 sj my inlet it roughly 30mm yes i now pee shooter and the smallest inlet i can find on a cherry bomb is 38mm would it be alright to modify it a bit
could pug it by mig welding it but thats bit of a bodge at 8mm :lol: ,
or another option what i would to is cut loads of equal lines down the tube and bend then inwards onto the 30mm pipe then weld it up ;)
another option use one of theses because you would be able to crush the 2mm differents with a exhaust clamp n paste ;)
Re: cherry bomb
Posted: Wed Apr 11, 2012 9:02 pm
by dazerede
chears might go and do some shopping naw
Re: cherry bomb
Posted: Thu Apr 26, 2012 12:45 pm
by charger
I have a Cherry bomb silencer, from the manifold I have a Peugeot 206 exhaust system that goes into the Cherry bomb. Sounds great & everything fits well.
Re: cherry bomb
Posted: Thu Apr 26, 2012 1:52 pm
You could weld a ring around the exhaust pipe, then weld the cherry bomb onto the weld line.
That will give you a bit less distance to bridge!
