Page 1 of 3
vacuum hose on standard 8v carb
Posted: Wed Apr 11, 2012 5:51 pm
by turbo-tom
can someone tell me were is the vacuum hose on my engine so i can put a t peice in and put my vacuum guage in
pics would be easier
thanks guys
Re: vacuum hose on standard 8v carb
Posted: Wed Apr 11, 2012 6:16 pm
Why do you want a vacuum guage? There's no need whatsoever on an SJ engine?
Posted: Wed Apr 11, 2012 6:33 pm
by turbo-tom
ScottieJ wrote:Why do you want a vacuum guage? There's no need whatsoever on an SJ engine?
because i just simply want to thatts all, and it got it pretty cheap
Posted: Wed Apr 11, 2012 9:36 pm
by turbo-tom
anyone got anypics to show me ?
Posted: Wed Apr 11, 2012 10:21 pm
by Tramp
I know mine is a weber but the inlet manifold is the same.The x2 stabbings which the Orange pipes attach to will give you the pressure/vaccum in the inlet manifold.
Posted: Wed Apr 11, 2012 10:45 pm
by turbo-tom
cant see the image tramp
, the wording sounds good though
Posted: Wed Apr 11, 2012 10:48 pm
by dan_2k_uk
neither can I.
Basically one of the little brass fellas that stick out of the area of the manifold under the carb.
Will try find a photo now.
Dan
Posted: Wed Apr 11, 2012 11:02 pm
by turbo-tom
cheers dan would be very helpful if you can
Posted: Wed Apr 11, 2012 11:21 pm
by dan_2k_uk
on this photo either of the bits where the bits of pipe have been doubled back to blank pipes off would be good
Posted: Wed Apr 11, 2012 11:22 pm
by turbo-tom
okay cheers dan
, shall put it in tomorrow then
