how much you you spend on a jimny power steering box ?
seen a few around the £100 mark is that about right ?
only because i cant be arsed to faff around with the wedge thing , unless someone wants to make me one and ill buy it off them ?
- turbo-tom
Re: jimny power steering box
all the ones ive seen are £100
- turbo-tom
£100 it is then , does anyone know who makes wedges though ?
I'd make you one when I get my welding gas!!!
Surely there must be a steering box in a jimny at a scrappy? they wont be able to tell the difference between that and a vit one! You could probably blag one for £20-30
- justaddmud
- Can I have a tow
mine cost £100 for the complete system, delivered from someone on differs
could always try one of the brokers that search all the breakers yards, used them a couple of time for hard to find parts and always get a result, sometimes cheaper too
- ianedwards
- SCUK Addict
I tried most of them the other day, £96 delivered was the cheapest quote I got. There are loads about, I'm just going to have to wait till I got a bit more dosh
Ian
Ian
Ian.
Ian.
Tom I might be able to knock you up a wedge. will pull mine off and take some measurements as I modified the original design to lower it a bit.
- turbo-tom
sweet well if you could it shall be great ill send you some dosh if you can knock me up oneScottieJ wrote:Tom I might be able to knock you up a wedge. will pull mine off and take some measurements as I modified the original design to lower it a bit.
