electric fan details
jgp1986
Post by jgp1986 » Sun Feb 12, 2012 8:20 pm
Im currently in the process of fitting an electric cooling fan, im using a top hose off a escort with a peugeot 206 thermostat switch to control it turning on and off, will this do or will i need another manual switch and anyone got the best way to wire it up?
cheers jonno
Re: electric fan details
Post by twiss » Sun Feb 12, 2012 11:19 pm
You want to use a relay to avoid sending much current through the switch.
You can put a manual inline switch if you want to switch it off for water wading
Like this but without the de-mist section
jgp1986
Post by jgp1986 » Sun Feb 12, 2012 11:27 pm
what will happen if it not turned off, will it speed up the water gettin into the engine bay?
Post by ScottieJ » Sun Feb 12, 2012 11:40 pm
The fan will just spray water throughout your engine bay and increase the chances of getting the electrics wet.
It's always good to have the option to turn them off
this is always a good one for reference wiring in fans with a thermoswitch.
http://www.x-eng.co.uk/Instructions/X-Fan.pdf
