Page 1 of 2
zuk sj build from scratch.....09
Posted: Wed Feb 18, 2009 1:20 pm
by peewee1976
hi all just though i would add this to show you what iam up to and your comments are welcome...
this anus started out life as a sj413 but i thought it looked ruff and ready for a complete overhall.
so as you will see soon that i have not wasted no time in cutting off everything that i no longer want,
inc-rear tub,front end,rear cross member,and much more....and questions or the likes please feel feel to ask,i will update
as i go on..peewee...18/02/09
this is how i got the anus,as you see it
Re: zuk sj build from scratch.....09
Posted: Wed Feb 18, 2009 1:32 pm
by peewee1976
here is a load more photos and what we have got up to with the
zuk....
Posted: Wed Feb 18, 2009 1:38 pm
by peewee1976
well after this lot we have now got lots more done and really going to town on it now
Posted: Wed Feb 18, 2009 1:43 pm
by peewee1976
now we have done what we can on the rear loop and cage,now we must get out the disc cutter
and chop the front off,everything must go.....
Posted: Wed Feb 18, 2009 5:53 pm
by urbanzook
yer man looking good
Posted: Wed Feb 18, 2009 6:52 pm
by peewee1976
thanks for that chap,still got lots more to do yet,just made up the brackets to hold the vitara power steering pump today and in order for that to fit we have had to cut the shaft which holds the steering wheel down about 1 and a half inches,got that on now and now we have just got the double pulley for the crank to take the power belt and fan belt,but we had to re drill the holes as the standard 1.3 v-groove pulley has 4 holes where as the double pulley has 5 but all off set...and also that the pump that bolts on the engine with the pipe is about 2inches 2 big,so now we have cut a small section out of the chassis then reinforced it to get round that problem....will post photos of that soon....no for a chill out as off up to the indoor 4x4 show at donnington on sunday...great early morning start.lol
Posted: Wed Feb 18, 2009 9:10 pm
by carnut
LOOKS TOUGH! WHAT ENGINE YOU RUNNING.
Posted: Thu Feb 19, 2009 12:16 am
by bourneyo
Welcome to the forum! :beer:
Cant wait to see her finished!
Dan 8-)
Posted: Thu Feb 19, 2009 8:29 am
by peewee1976
well its got a 1.3 in it at the mo,but prob end up keeping it in there,just in the prosess of sorting out a su for it but got a mate who can make me an inlet manifold for it to take 2 su's so mite do that for a change.....
Posted: Fri Feb 20, 2009 2:54 pm
by peewee1976
hi all again,well back now with more photos with my rebiuld and info in to what we are doing
as you will see we are at the mo doing a power steering convertion with a vitara pump,box...and moving the pump to a diff location on the engine to save from cutting the chassis or the likes,also how to keep the original pulleys and still use the double pulley for the steering.....
