Rear axle angle correction wedges???
little confusion... swapping rear springs and found some little wedges between the spring & axle. I think they're there to lift the nose of the diff to make a better angle for the prop shaft because we have a SOA set up fitted B4 we got the truck. They don't have a stud or anything to index them to the axle. Any ideas???
Re: Rear axle angle correction wedges???
Would guess that might be the case. Maybe whoever did the spoa conversion welded the saddles on at the wrong angle and did that to correct it.
Dan
Dan
