what wire does what...
Posted: Fri Dec 23, 2011 12:20 am
Home of all things Suzuki 4x4
https://suzukiclubuk.co.uk/forum/phpBB3/
https://suzukiclubuk.co.uk/forum/phpBB3/viewtopic.php?t=4069
believe everything works allright , there in the main wireiing loomHenry wrote:Where do they come from?
Anything not working?
nopee i think its beena 413 all its lifeScottieJ wrote:Was your SJ originally a 410?
If so the brown and black with yellow tracer used to be part of the ignition wiring for the ballast resistor.
Black with white tracer is an ignition live so you don't want that shorting out on anything
Yellow with white should be going to your alt? The plastic bit at the end is covering 1 half of a fusable link, the other half would then be connected to the + on the alt?
