1.6 conversion inlet manifold gasket
Posted: Mon Nov 21, 2011 7:44 pm
by dcallaghan2011
Hi, I have just hot my 1.6L carb vitara engine up and running in my SJ, however i need to replace the inlet manifold gasket before it can go anywhere, I have used the 1.3L SJ manifold as I already had a webber carb and everything setup on it, so i was wondering what gasket I should use?
Thanks,
Dan
Re: 1.6 conversion inlet manifold gasket
Posted: Mon Nov 21, 2011 9:31 pm
by Russ24
i put a 1.6 vitty lump in mine. used the same inlet manifold. as i didnt detach SU carb.
used SJ 1.3 inlet manifold gasket. no problems.
Posted: Mon Nov 21, 2011 9:54 pm
by dcallaghan2011
Ok thats great, thanks for the help
In the kit below would is that the top or bottom inlet gasket?
http://www.ebay.co.uk/itm/SUZUKI-SJ413- ... 1c088a6bbe
Posted: Tue Nov 22, 2011 12:19 pm
by dan_2k_uk
The top one looks like a 1.3 gasket i fitted to a friends the other day. The lower one is a 1.6 obe but i guess either will fit. The studs and holes are all in the same place and the difference in the size of tge ports is less than a mill.
Dan
Posted: Wed Nov 23, 2011 2:43 pm
by Russ24
dan_2k_uk wrote:The top one looks like a 1.3 gasket i fitted to a friends the other day. The lower one is a 1.6 obe but i guess either will fit. The studs and holes are all in the same place and the difference in the size of tge ports is less than a mill.
Dan
i used the top one. as its slightly thicker.
as i had the other one on when i fitted it to the previous engine.. it failed rather quickly on its own.
top definitly
Posted: Thu Nov 24, 2011 7:13 pm
by dcallaghan2011
Ok thanks for the replies
Posted: Sun Feb 17, 2013 10:05 am
by dannytrigger
did your ilet manifold bolt straight on? mines touching the fuel pump!?
