Air intake for Weber Carb
Does anyone know where I can obtain an Air Intake for a Weber Carb (the airbox which sits on top of the carb) please.
Re: Air intake for Weber Carb
You mean the plenum chamber? Or the bit of rubber that goes between the plenum. & the airfilter? I may have got a part number for the plenum so weber will be a ble to supply you with a new one although I imagine they will be expensive! The rubber is just a standard SJ part
