Now lifted before & after
Posted: Fri Nov 11, 2011 11:24 am
Home of all things Suzuki 4x4
https://suzukiclubuk.co.uk/forum/phpBB3/
https://suzukiclubuk.co.uk/forum/phpBB3/viewtopic.php?t=3864
Add a Leafs it look more than 2" to me though, the clearance from the ground to sill is over 20". Need rear shocks first then will get new rubber.twiss wrote:Hi, that's a very white SJ!!!
How did you lift it up? Lift springs or add a leaf?
The front looks quite a bit lower than the back... maybe worth knocking up some slightly extended shackles so its the same height?
Up to you though!
