brake servo
martin1973
brake servo
Post by martin1973 » Wed Jun 22, 2011 7:49 pm
has anyone fitted a remote servo to a 410q?
or is it possible to fit a servo/mastercylinder from another sj?
Re: brake servo
Post by twiss » Wed Jun 22, 2011 9:53 pm
I guess it might be possible, but I dont know if the 410 manifold would have a vacuum hose to power the servo?
martin1973
Re: brake servo
Post by martin1973 » Wed Jun 22, 2011 10:10 pm
cheers
my 410 has the egr vac point on manifold,
it does do anything due to having su carb and k/n filter, and crankcase/ rocker breather pipe goes to a catch tank.
vac point is blocked off.
Henry
Re: brake servo
Post by Henry » Wed Jun 22, 2011 10:22 pm
Me being thick..... whats a remote servo :er:
Re: brake servo
Post by twiss » Wed Jun 22, 2011 10:26 pm
I'm guessing he just has an old 410 without the servo.... and wants to put a samurai servo/cylidner combo on
Re: brake servo
Post by ScottieJ » Wed Jun 22, 2011 10:47 pm
Yes you can do it, 2 ways.
1. find a 413/sammy with a servo and take the servo, mastercylinder and complete pedal assembly. Enlarge the existing hole in the bulkhead and fit.
2. Get just the servo and master cylinder from a 413, sammy or vit and take out your existing pedal assembly and do a bit of cutting and trimming so that the master cylinder fits it. Enlarge the hole in the bulkhead and fit, you might need to modify the throttle cable routing though, I've got to on mine. It's quite easy to do really, only thing is on a vit master cylinder there are 3 outputs, either blank one off or run 1 line to the rear brakes and 1 to each of the fronts :thumbup: It's not all plumbed in yet but have a look here http://www.suzukiclubuk.co.uk/phpBB3/ph ... &start=130" onclick="window.open(this.href);return false;
Lil_Beastie
Re: brake servo
Post by Lil_Beastie » Thu Jun 23, 2011 7:17 am
Make sure its not a lycos, cos if/when it brakes, youll struggle finding a replacement, let alone new master cylinder.
Just saying.
martin1973
Re: brake servo
Post by martin1973 » Thu Jun 23, 2011 8:16 am
ok thanks people.
Re: brake servo
Post by Edweird » Thu Jun 23, 2011 11:16 am
Is it worth fitting power brakes? You don't get abs with the servo, and I can (and have) locked up more than one wheel on dry tarmac with the un-assisted setup. Won't you just end up with really sensitive, overpowerful brakes?
Lil_Beastie
Re: brake servo
Post by Lil_Beastie » Thu Jun 23, 2011 7:10 pm
should just make the pedal easier/softer to use.
