alternator problems AGAIN
martin1973
Post by martin1973 » Thu Jun 09, 2011 7:51 pm
1985 sj410q
so before my the headlights went dim when reving the engine.
new earth strap fitted, problem solved.
now i have the sj on the road i could smell the battery cooking/ over charging! :yuk:
so i checked the output voltage ok (13.5) at tick over but rev up 1000rpm +
and output voltage to between 16 -18volts? :shock:
think the regulator is shot :argh:
re soldered the connection just incase its a dry joint. but still same? :argh:
so is it possible to get the just regulator pack? :idea:
Re: alternator problems AGAIN
Post by twiss » Thu Jun 09, 2011 9:44 pm
Can you get the alternator model number?
martin1973
Post by martin1973 » Thu Jun 23, 2011 8:20 am
couldnt find any numbers on the alternator,
so i binned it and fitted an old lucas one from a mgb, i just had laying around
all sorted.
Post by ScottieJ » Thu Jun 23, 2011 9:25 am
:good:
