Love the fact the blue zook at 1.46 gets up that lump just by keeping the momentum, it looks the most standard
check it out
http://www.youtube.com/watch?v=2Z1xpIjy ... re=related
zooks
- Edweird
Re: zooks
As I understood it with off-roading, momentum gets you places, too much breaks things, not enough and you get stuck.
Re: zooks
Can fully appreciate that. Normally a feat isnt pissed over quite so easily, He must of done that route before that or hes the golden mutts nuts.Edweird wrote:As I understood it with off-roading, momentum gets you places, too much breaks things, not enough and you get stuck.
nothing more statisfying then when a plan comes together. or buy one like these
http://www.youtube.com/watch?v=yuhUw69FP_o&NR=1
http://www.youtube.com/watch?v=1yonv8SZC5Y&NR=1
http://www.youtube.com/watch?v=3PEJU_CVGVQ&NR=1
Re: zooks
Not usually. yes it works in a straight line, but if you have to do technical driving, slower the better, with power in the pedal as and when you need it.Edweird wrote:As I understood it with off-roading, momentum gets you places, too much breaks things, not enough and you get stuck.
