Exhaust manifold bolt
Posted: Thu Dec 30, 2010 7:48 pm
Not sure if this is the place to put this but here goes.
My exhaust is blowing where the manifold meets the down pipe. All it needs is a new gasket and tightening up... however... 2 of the 3 nuts have sucessfully come undone while the 3rd one has rounded.
As many of you probably know the nuts are downwards facing so rather fiddly if, like me, you are attempting to fix this on the driveway.
I need to get this nut off now either way, but my question is what is the best way to go about it?
I know you can get those nut extractors that eat into the nut to remove it, but halfords only sell them in sets up to 12mm when my nut is 14mm
I also considered putting some chemical metal inside a 14mm socket and holding it in place until it sets - but my worry is getting the chemical metal where I dont want it and having a socket stuck over the nut I cannot remove
I dont think a nut splitter would fit given the lack of space I have to work with.
I have thought about using a hacksaw to cut the bolt, but the bolt seems to be part of the manifold so then I would have to either hope I can drill the rest of it out or hope that I can get a decent seal with only 2 bolts?
Oh yea I also tried whacking a 13mm socket on, but there isnt a lot of space to try and do this from underneath on the driveway so this was not successful
Any suggestions? Its really doing my head in lol
