1600 engine swap issue
Posted: Mon Jun 14, 2010 10:11 pm
by kgilmore
Hi,
I have been planning to put a vitara 8v engine into my samurai for a while, but when I was removing it from a scrapped vitara there seemed to be way too many wires connecting to the engine, which i no my sj loom wont have. They were mainly connecting to the carb, has anyone done this before or can give any advise.
Cheers.
Re: 1600 engine swap issue
Posted: Tue Jun 15, 2010 10:02 am
by Henry
Just make sure it is the carb engine (a big black round filter on the top of the eninge) and not the 8V EFI.
Only wires that i can think that will go to the carb (off hand) is the fuel cut of switch and possibly an idle up.
I would just cut these wires of, get the engine in. The standard 1300 carb should have a fuel cut of switch, then just wire it up. I didnt bother with the standard vit carb, chucked that away and smacked the su on... 10 times better.
Can you post a pic up of the engine if you are not 100% sure that it is the carb over the EFI?
