Page 1 of 2
temp and fuel gauge dont work :S
Posted: Wed Apr 28, 2010 9:43 pm
by farmerben
hi,
my temp and fuel gauges have stopped working i took the dash out and had a look all seems fine there ,any ideas?????
many thanks , ben
Re: temp and fuel gauge dont work :S
Posted: Wed Apr 28, 2010 10:46 pm
by Pugsley
Ben
both gauges probably share a common earth or possibly a common connector plug which may be causing the problem - you haven't stated what the vehicle is. If it's a SJ410 I can look on my wiring diagram but otherwise that's as far as I can go.
Ian
Posted: Thu Apr 29, 2010 12:11 pm
by gsommo
I have the same problem on my 87 sj413. To be honest I do not even know where to start with them. I have an aftermarket fuel tank too, so how do I conmect a fuel gauge to his aftermarket item. Also where is the temp gauge located?
Posted: Thu Apr 29, 2010 9:02 pm
by farmerben
hi
sorry i forgot to say its a 1990 samurai sj413 .
Posted: Thu Apr 29, 2010 9:05 pm
by Henry
Fuses (dont know if they are fused) and earths would be my first point to call.
Does everything else work on it? lights on the dash, dash lights up ect.
Posted: Thu Apr 29, 2010 9:17 pm
by farmerben
yee everything works apart from the temp and fuel :S
Posted: Thu Apr 29, 2010 10:03 pm
by Henry
Does sound like an earth to me.
Not sure what else to suggest other than try another set of dials.
Posted: Thu Apr 29, 2010 11:25 pm
by Pugsley
You are going to have to get hold of a wiring diagram and trace the wiring by their colour codings - you should be able to see if the earth for these gauges is common to both or indeed a connector block. Alternatively you may have to remove the gauges and trace the wiring backwards to achieve the same thing.
Posted: Fri Apr 30, 2010 10:30 am
by Henry
I have wiring diagrams on my computer.
When I get home I will post them up.
Posted: Tue May 04, 2010 9:11 am
by farmerben
hi
today they just came on :s all working fine now :s don't no why ?
