Steering box jammed
Posted: Wed Feb 17, 2010 6:20 am
by malie
hi..i just got another rusty SJ410 ( post the pic sum other tym havt take the pic yet )...
my problem is the steering box is jammed!!... can it be repair ?.. or can it replace with vitara steering box ?
malie
Re: Steering box jammed
Posted: Wed Feb 17, 2010 10:36 am
by chan
hi there.
you can replace it with a vitara pas steering box but takes a bit of modding..
or just use an sj410 steering box?
Posted: Wed Feb 17, 2010 12:49 pm
I think they are pretty simple so i would just take it off, strip it down and clean it all up, it's probably just leaked all it's oil and seized up.
Posted: Thu Feb 18, 2010 12:49 am
by malie
hi guys..
thnk for da reply
i took it off yesterday and strip it off, found out tiny little ball bearing fall out and the gear very rusty..try put WD-40 but the gear wont move...
thnk i need to change it but as you can see here at my place (brunei) searching for SJ part is slightly difficult,try to search for it anyway,wish me luck guy hehe..
Malie
Posted: Thu Feb 18, 2010 11:00 am
fleave it to saok for a few days with a good coating of wd40 and it might free up
Posted: Thu Feb 18, 2010 1:14 pm
by Tramp
scottiej410 wrote:fleave it to saok for a few days with a good coating of wd40 and it might free up
if the bearings have come out you will have trouble, i once set about rebuilding a steering box, but I couldnt get the seal for the input, it also needed a special tool to remove it, all the bearings are standard items so if the seal isn't shot and you can get the old seal out i can't see why you can't rebuild it,
Luke
