taking the zuke off the road for a while!
Post by ScottieJ » Wed Aug 27, 2008 12:23 pm
well i'm moving to bath at the end of the month and my tax and insurance runs out too! why does everything happen at once :lol: But on the plus side, my new pad has a nice big double garage so i'm gonna get Mr Angry (the angle grinder) out and have a bit of fun with the zuke. Thinking about chopping out the arches and modifying the bulkhead to try and squeeze some 33s on :twisted: without lifting the zuke any higher! as well as that i've got an SU carb to fit, an engine rebuild as my piston rings and valve stem oil seals are on the way out and some sammy axles to fit, hopefully with some vit R&Ps!
froggy
Re: taking the zuke off the road for a while!
Post by froggy » Wed Aug 27, 2008 1:43 pm
Well Scottie, seems that you'll be busy !!!
Fitted your wheel spindle on Carlos at the week end. Great.
Now in the middle of axial diff oil changing, motor oil changing, new sparks, air and oil filters. Hopefully should pass the MOT next week.
See your new modified Zook soon and good luck with the grinder !!
Cheers,
:lol:
trotter
Post by trotter » Wed Aug 27, 2008 6:06 pm
join the club dude mine is off the road till i decide how much to spend and what to do
if in doubt, FLAT OUT!
urbanzook
Post by urbanzook » Wed Aug 27, 2008 7:32 pm
she will be misst
Post by ScottieJ » Thu Aug 28, 2008 12:14 pm
Its all good there will be plenty of pics of all the work i'll be doing!
So trotter are you not going for the 5" calmini lift then? i think you should its an awesome bit of kit!
trotter
Post by trotter » Fri Aug 29, 2008 8:38 am
still not sure yet depends on work an stuff at min as to whether i have the spare cash to throw at it i'l keep you informed as an when it happens tryin to sort out somewhere to put zuke for a while an try an take the body off chassis to repair the rot
