Left side electronic window relay location?
SamFoley7
Post by SamFoley7 » Wed Feb 28, 2024 10:15 am
Hi, I have a Suzuki Jimny 2003 Right hand drive Manuel.
The left side window has recently stopped moving after installing new speakers, I cant seem to find where the relay for the electric windows is located. Has anyone got a wiring diagram or know the location of the relays? Thanks.
Brady
Re: Left side electronic window relay location?
Post by Brady » Thu Mar 21, 2024 12:12 pm
Typically, the relay for the electric windows hangs out in the fuse box, which could be hiding under the dashboard on the driver's side or chilling near the battery under the hood. Check out your owner's manual or the diagram inside the fuse box lid to pinpoint which relay is for the windows.
Once you've tracked down the relay, give it a once-over for any obvious issues like damage or corrosion. If everything looks okay, you might want to consider swapping it out just in case.
