Engine coolant temperature sensor location Jimny 2005
Graba
Post by Graba » Wed Nov 25, 2020 3:17 pm
Hi all,
I am new to the forum although I had my Jimny for a while, but as things started to go wrong I decided to get my hands dirty and do the work mysel, hopefully you can help me. I need to change engine coolant temperature sensor but have no idea of the location. Part supplier told me that there are two possible options, either 2 pin oval shape connector or 3 pin triangle shape. I can’t find either, although I found number of sensors on the car I can’t figure out what is what. The car Jimny 2005 manual, 1.3 petrol with a second gearstick for 4wheel drive and low ratio. I attach pictures with sensors I found on
the front of the engine,
next to / behind alternator,
around throttle body (3 offside 1 near side ),
one behind / below throttle body (kind of on the block)
Any help greatly appreciated
Thanks
