Temp guage
Posted: Fri Aug 23, 2019 7:47 pm
by hcloseuk
Hello everyone I'm new to the Vitara I've just purchased a 2009 2.0 Vitara and just noticed that the temp gauge is only moving up about a quarter of the way even after a good run is this normal or a fault. Thanks
Re: Temp guage
Posted: Tue Aug 27, 2019 11:03 pm
suzuki gauges do quite often only sit around 1/4 of the way up at normal running temperature, however it might be worth checking that the thermostat hasn't been removed by a previous owner and that it's opening at the correct temp.
Re: Temp guage
Posted: Wed Aug 28, 2019 7:16 am
by hcloseuk
OK thank you I will check it out
