Unknown Power Loss
Posted: Wed May 08, 2019 12:04 pm
I was driving along the road in my 02 registered Jimny when the engine just died. I managed to drift to the side of the road and tried to restart and athough the engine turned over, it would not start. I assumed that I had run out of fuel despite the guage showing that I have quarter of a tank, but called the garage and they recovered it and I put more fuel in - still will not start. The mechanic had a look at it and said there was no fuel coming through so it was probably an issue with the fuel pump and they would fix it.
However, the next day after the mechanic tested the car it transpired that there was no spark at the plugs either and although everything else was working, the car would not pump fuel or make a spark at the plugs.
My mechanic is not over-experienced with this issue and is confused at what is happening and has assumed that the issue is the ICU but thats as far as we have got so far.
Has anyone had this problem, or can anyone help resolve it?
Any information would be much appreciated, thank you in advance.
