Oil light reset
Posted: Fri Feb 01, 2019 10:36 pm
by Newry
I have a2016 Diesel Vitara 4x allgrip auto and want to change the oil myself. How do I reset the oil change light. The YouTube instructions don't work.
Anybody have the correct method without a Dealer computer.
Re: Oil light reset
Posted: Mon Jul 08, 2019 7:33 am
by Newry
Had to get the dealer to do it
Re: Oil light reset
Posted: Tue Oct 08, 2019 4:19 pm
by Fenstead
Any garage with a generic reset tool can do it, not a job you can do yourself. My local independent reset mine.
Re: Oil light reset
Posted: Fri Oct 11, 2019 9:03 pm
by Anton
Anyone with an OBD2 reader should be able to do it. *should*...
Re: Oil light reset
Posted: Tue Oct 22, 2019 7:48 pm
by Fenstead
Anton wrote: ↑Fri Oct 11, 2019 9:03 pm
Unfortunately, an OBD tool won't do it. My independent has a generic (Sun I think) tool that can do it, it's been done many times.
Re: Oil light reset
Posted: Mon Oct 05, 2020 10:32 am
by Forfoxake
Newry wrote: ↑Fri Feb 01, 2019 10:36 pm
Anyone found a solution to this yet? Thanks in advance.
Re: Oil light reset
Posted: Mon Aug 02, 2021 10:34 am
by Newry
Had to go to the dealer. No work around available for the diesel engine.
Re: Oil light reset
Posted: Mon Aug 02, 2021 8:49 pm
by Parkey72
1. Foot on accelerator and keep it depressed.for entire procedure.
2. Power on button twice to switch ignition on but not engine.
3. Press Left trip button until odometer B is selected.
4. Press and hold Right menu button.
5. Pump brake pedal 3-4 times and wait.
6. When Change Oil Warning has cleared, release the accelerator.
Job done... It may take more than 1 attempt.
Re: Oil light reset
Posted: Sat Nov 20, 2021 3:22 pm
by Sparkey
Went into reset menu, and no oil change to clear on dash available,car is vitara 1.6 deisel 2016, so tried this method, foot accelerator down,power up twice,but not start,pressed left then right trip and light dash buttons holding down right while pumping foot brake 3-4 times, oil change light then went off ,release foot accelerator, it does work, garage quoted me £ 20 to do it. Thank you Parkey 72
Re: Oil light reset
Posted: Thu Nov 23, 2023 11:51 am
by Irishmoonbeam
Thanks Parkey72. ..it worked perfectly
