Carb advice please
Posted: Sat Jul 14, 2018 1:20 pm
by Pishadeperro
My LJ 80 has a 410 engine I think, but I can't get her to run right...I suspect it's the carb, can anyone give me some advice on which carb I should have and where I can get one from
Dean
Re: Carb advice please
Posted: Sun Jul 15, 2018 12:17 am
by Anton
If that's what I think it is (SU HIF38) then that's the right Carb for the job. If it's a HIF44, then it's probably too big for the 1.0.
If it won't run right, you'll need to find out what needle and spring it's got in it, it won't run right with the wrong ones.
My advice is to get a Colourtune kit, works wonders for me.
Posted: Sun Jul 15, 2018 10:55 am
by Pishadeperro
Can't see what type it is...but I've ordered a colourtune kit...thanks for the advice.
Posted: Tue Jul 17, 2018 12:59 pm
by Anton
Regarding the needle and spring, https://burlen.co.uk - give them a call, they can tell you how to work out which needle and spring you have installed. They can also help you work out if you have a 38 or a 44.
You'll have to do a search on the forum for "HIF38" - somewhere on the forum is the info you need on which needle/spring you should install. Burlen will have them.
