I have to Suzuki SJ410's with Vitara 1.6 8v engines. One came with a carb and never ran right. High idle and random cutting out. the other didn't come with a carb. Bought another carb the same and want to get both to run right. When warm the second one runs and idle's fine once i mess with vacuum hoses.
Does anyone have a picture or hose diagram for the carb and/or inlet manifold with the little vacuum sensors, what each one does etc. Mainly need cold start and idle to work fine, everything else seems fine and they both have shit loads of power.
Oh both have slightly different manifolds, and the second one came with one the same and one different fitted. here's some pictures.
http://imglnk.uk/img?i=jAlWpT.jpg
http://imglnk.uk/img?i=aNcZwA.jpg
Thanks
SJ410 with 1.6 Vitara engine 8v with Mikuni Carb
1985 SJ410 1.6 Hammerite Black for on/off roading
1987 SJ410 SPOA 31's Green welded diffs Offroad only (Brothers)
1991 Toyota Hilux MK3 2.2 Petrol Black
1994 Toyota Surf Gen 2 3.0TD 33's Lifted winch Black
