Sagging leaf and rotating axle
Posted: Sun Feb 25, 2018 9:23 pm
Hi all,
My OS leaf spring has been sagging for a while now. Today I decided to jack her up and figure out what the problem was.
When I jacked up the chassis with the axle hanging free I noticed the following (see video link below). this was when I tried to rotate wheel back and forth with handbrake on. This seemed like a lot of play to me. I could feel this when taking up drive between 1st and reverse etc..
Click Here for Youtube Video
Having now removed both rear leafs I think the axle rotation was mostly down to a loose u bolt on the near side.
The lower leaf on the OS was a little crooked so I'm not sure if this was the cause of the sagging as now that everything is removed left and right leaves look identical.
Can anyone point out any obvious errors or problems here??
Otherwise my next move is to grease and reassemble everything correctly and see how she sits then.
