Breather to Transfer box?
Phillips321
Post by Phillips321 » Mon Jan 08, 2018 4:14 pm
Hi guys,
I've got breathers on my diffs but need to do the one on the transfer box. Is there an easy way to do this one?
And do I also have to do the gearbox?
Thanks
SherwoodNash
Re: Breather to Transfer box?
Post by SherwoodNash » Mon Jan 08, 2018 5:09 pm
Hey, welcome back ;)
I've no need to do mine, but here's a link to the basic SCUK 'how to guide' if you haven't already seen it:
http://twiss.ddns.net/scuk/diy/16-trans ... -breathers
Post by ScottieJ » Tue Jan 09, 2018 12:43 pm
Pop the cap off the tbox breather, then get some mole grips to remove the steel insert. Tap the hole to 1/4"BSP and then there's a choice of attachments you can use for breahters.
I use fittings like these for 8mm tube https://www.ebay.co.uk/itm/Norgren-Swiv ... SwB4BaGrsq
Gearbox you can also remove the small breather barb in the same way but you need to drill it out to tap it to 1/4" bsp if i remember correctly or you can drill the small hole out in it and weld/braze in a small bit of 6mm tube in to attach a breather pipe to.
zook123
Post by zook123 » Tue Jan 09, 2018 1:29 pm
I use a small (2cm) line of Garden Hose, clamped on with a jubliee clip, with this stuffed in the end
https://www.ebay.co.uk/itm/361220619356
Then I run the 6mm air pipe to the bulkhead (and need to tidy it up)
Saves tapping threads, and having to replace fluid after.
I've done the same on Gearbox, Trans and Diffs, never had an issue this way!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Post by ScottieJ » Tue Jan 09, 2018 1:37 pm
Jimny's are different
Plus if you grease the tap it catches most of the swarf. A tiny bit of aluminium swarf is going to do no damage to a gear or transfer box.
zook123
Post by zook123 » Tue Jan 09, 2018 1:38 pm
ScottieJ wrote:Jimny's are different
Isn't the transfer box very similar, with the small 4mm lip around where the breather goes?
Post by ScottieJ » Tue Jan 09, 2018 1:41 pm
possibly but there isn't enough purchase on the sj one and just a hose jubilee clipped on is a big gamble. They can easily come off and then you fill your transmission with water without knowing.......ask me how i know :hahaha:
Never again will i do it that way, better to have something 100% reliable.
