Something needs to go so its either the following Jimny or the new SJ.
On/Off Roader Year 2000 (Makes it the slightly Cheaper Tax) with a DOHC Engine.
This little Jimny is not your normal Rot Box.
All This Work has been done Prior to last MOT and has only done 568 Mile since then. Present Mileage 112508
MOT Due 01/11/17 (MOT Tester did say it was like doing a MOT on a new Car LOL)
List As Follows.
Removed The Body and Welded All the Usual Rot including a New Rear Floor with 2"x1" Box Section and Flat Plate Steel, All Body to Chassis Mounting locations Inner Sills plated up, and any other plates that were found then painted everywhere with copious amounts of industrial Chassis paint.
Rear Seats have been removed but will be included in sale but will need a bit of fabricating to reinstall due to floor shape
2inch Body Lift and 2-3 Inch Suspension Lift (New springs and Shockers) will allow Bigger wheels and tyres
Jimny Bits Steering Damper Kit
Bits 4 Vits Heavy Duty Transfer Box Mounts
Bits 4 Vits Complete Suspension Poly Bush Set including Castor Correction Bushes
New track Rod Ends
Aisan Manual Front Hubs (I do still have air ones with pipes that will be included)
New Blue Print 3 piece Clutch
New Awesome Heavy Duty front Bumber and 13500 lbs Winch Never Used and will require Connecting Up
Jimny Bits Transfer Box Guard Skid Bash Plate
Jimny Bits Heavy Duty Fuel Tank Guard
New Copper Brake Pipes from Front to Back
Complete Jimny Bits Stainless Steel Extended Braided Brake Hoses
Refurbed Front Calipers
New Rubber Petrol Pipes front to back
Jimny Bits Snorkel
Twin Battery Plate installed.
Plus really anything else that was done while it was stripped down
£2000
X Reg DOHC Jimny
X Reg DOHC Jimny
You do not have the required permissions to view the files attached to this post.
- SlimGrim
- Winching along now
Re: X Reg DOHC Jimny
Ball park price?
___________________
Sorry I would like £2000 as it stands or I might bite the bullet and break this or the SJ
