Slight Idle Problem
Posted: Fri Apr 07, 2017 9:49 am
by scot the sniper
when idling in the jimny 04 plate btw it ticks over fine but quite a few times it dips in power. its like ur sitting nice and quiet idiling then it feels like someone has switched the heater rear demister on as you know that pulls alot of power from the battery on any car so it feels like someone has switched this on and it dips in power does it quite frequently and im sure its causing jimny to cut out you seem to just touch the throttle at times and it cuts out u need to give it plenty revs so it doesnt cut out any ideas guys its doing my head in maybe someone has had this before and cured it hopfully.
cheers
scot
Re: Slight Idle Problem
Posted: Fri Apr 07, 2017 9:51 am
by zook123
When did you service the engine last?
Posted: Fri Apr 07, 2017 9:55 am
by scot the sniper
only got jimny a month ago serviced it straight away
Posted: Fri Apr 07, 2017 10:10 am
by zook123
Did you replace that sensor that kept making the engine not stop?
Posted: Fri Apr 07, 2017 12:11 pm
by scot the sniper
If the car stalled it would not start again fitted cam sensor from main dealer all good now
Posted: Fri Apr 07, 2017 1:04 pm
by zook123
Quick google and someone else has had the problem, sticky throttle position sensor
https://www.bigjimny.com/index.php/foru ... ut=default
