Page 1 of 2
Anyone identify a transfer box from the outside?!
Posted: Tue Mar 14, 2017 7:19 am
by mike harris
Tbox I got in my garage, it's jammed just want to know what it is.
Re: Anyone identify a transfer box from the outside?!
Posted: Tue Mar 14, 2017 7:21 am
by mike harris
Thought that type of handbrake leaver is 410?
It has a 410 knob on it but I know that's the same as sj413
Without taking it apart to see if it's 410 I thought someone may be able to tell the difference from the outside, no point in stripping it really if it's a 413 !!
Mike
Posted: Tue Mar 14, 2017 8:29 am
They are identical externally so unfortunately not.
Posted: Tue Mar 14, 2017 10:37 am
by mike harris
Thought 410 and 413 have different styles of handbrake cable?
Posted: Tue Mar 14, 2017 10:39 am
by mike harris
Thisbhas a large flange input on it so pretty sure it's 413
Posted: Tue Mar 14, 2017 10:48 am
Yes but who knows what has been retrofitted / swapped over during the years on sjs.
The prop brakes didn't come in large flange so either that has been fitted or the large flanges have been fitted.
Posted: Tue Mar 14, 2017 11:18 am
by mike harris
Yeh I think il split it and count the teeth maybe then.
I've got 5 so just trying to work out which ones which
Posted: Tue Mar 14, 2017 10:40 pm
Whats the handbrake adjuster on the back like? Then you can tell if its Jap or Spanish at least. The handbrake cable is the same as my Spanish SJ410 one, but they could be the same jap/spanish as well.
Mines spanish and its got a square nut thing on the back for adjustment
Posted: Wed Mar 15, 2017 7:12 am
by mike harris
I'm not sure il just split it and find out.
Anyone know the teeth count it would need to be for 410 and for 413?
Posted: Wed Mar 15, 2017 8:54 pm
Not sure teeth count but you should be able to tell quite easily
