New member, gear ratio help needed 99 gv 2.0 TD Mazda engine
Posted: Wed Feb 08, 2017 4:39 am
Hello everyone,
I've been wreaking my head trying to find some relevant info allover the Internet but it seems that I'm the only one with this problem. Basically the gear ratios are different between the two axles, making the rear tires spin faster than the front. The speedometer seems to be accurate and the rear diff it's a torsen LSD (not sure if it's standard) . I'm only able to use 4wd on a very loose surface, as soon as I go on a harder surface, the front wheels have to stop every few seconds to keep up with the rear. I'm enjoying the LSD and I wouldn't like to get rid of it but I'm not sure if I can change the ring gear for the same size as the front so I wouldn't have to deal with this any more. Both front and rear diffs look oem and don't seem to be tampered with from the outside. As soon as I get a chance I'm going to measure the diff ratio on both diffs and it would help if I had the right figure that came as standard (4.3:1 from what I have found, I hope that someone can confirm). Any suggestions for curing my problem are much appreciated. Thank you
