Page 1 of 5
Bad weekend
Posted: Tue Dec 20, 2016 4:41 pm
by zook123
For those that I don't have on Facebook or Instagram, the Jimny's engine let go after picking my fiancé up, the head gasket has been acting suspicious for a while, water disappearing, heaters turning cold, purchased a new radiator and fitted, worked fine and then driving home I smelt coolant, lost all power, pulled over and it stalled, looked behind and saw the road filled with smoke! Smelt really badly - so far that I got the Mrs out the car and grabbed the fire extinguisher.
So the question is, who fancies helping me disassemble the engine, advising what I should do at the same time and then coming down a second time (once the head is back) to reassemble.
Unfortunately the car is not drivable, I will cover petrol and time! Located in Shepton Mallet.
Thanks in advance!
Re: Bad weekend
Posted: Tue Dec 20, 2016 11:46 pm
by andyrew
Im under the impression this is fairly common with the g13bb lump
which i assume yours has being a soft top.
I should think youll be fine doing the job on your own. Just
label and store everything as you strip it down.
First major head change i done was on an 1.8 zafira that lunched its cambelt. What an awkward as job that is. On the jimny everythings where it should be and nicely accessible. Just label everything and box everything in an organised manor, take away tubs and small boxes are handy for this. Take photos of everything.
Or just shove some steel seal or k seal in it and hope for the best
Re: Bad weekend
Posted: Sun Dec 25, 2016 10:21 pm
by zook123
Gonna start stripping down over the next few days, just know I'll get stuck within 10mins!!
Re: Bad weekend
Posted: Mon Dec 26, 2016 1:15 pm
by dan_2k_uk
I don't think you will get stuck. There really isn't much to one of these engines.
Re: Bad weekend
Posted: Wed Jan 04, 2017 2:09 pm
by zook123
So, some success, got the head off thanks to a local friend/mechanic and also Dan and Scott!
Smokey!
Sorry sight!
Cylinder 4 looking a little wet
Starting to disassemble
It's off!!
Gasket looking a little sorry for itself, makes me wonder if the last owner really got this changed in April 15?
Re: Bad weekend
Posted: Wed Jan 11, 2017 7:58 pm
by Anton
That gasket clearly has another 100,000 miles in it. Put it back.
How's it going?
Re: Bad weekend
Posted: Wed Jan 11, 2017 9:10 pm
by zook123
Haha, I was thinking a bottle of kseal! It's still appear to waiting for payday! I started cleaning it today and boy is it gungy! Gonna get it sent for skimming soon!
Re: Bad weekend
Posted: Wed Jan 11, 2017 9:16 pm
by Anton
Does it need skimming? Or do you want an extra little bit of compression?
Re: Bad weekend
Posted: Wed Jan 11, 2017 11:20 pm
by Tramp
It makes you wonder if they had it skimmed last time the head gasket was done? Great work so far stick too it and it will be done in no time ,
Re: Bad weekend
Posted: Thu Jan 12, 2017 8:32 am
by zook123
After seeing the damage to the gasket, my mate said it's not worth getting it pressure tested, but i am going to get it skimmed.
Now I've taken it out,i'm pretty confident to do it again!
Yeah, they used a crappy gasket, that they drilled holes into, everything was bolted down the sealant!
