No power at ignition.
Posted: Sat Nov 26, 2016 12:21 am
Evening all,
I have recently got another soft top c reg sj410 in extremely good condition for almost free! Only problem is when you turn the key absolutely nothing happens. No clicks, sounds or lights on dash but full battery and the ignition barrel is plugged in etc.
Just wondering if there are any fuses i should check or any important cables other than the + and - terminals that i should check?
I haven't actually looked in to it much but just wanted some suggestions on things to check.
Any suggestions appreciated, thanks
