Steering joint
Steering joint
Hey guys quick question slowly going down my list of lil jobs , when i did my powersteering conversion i noticed the joint on the steering arm that connects to steering box could do with bin replaced , i have a z bar so just wondering can these even be replaced i carnt seem to find any on ebay thanks
Re: Steering joint
The ball joint on the end of the long arm? No they cannot be replaced. Only the screw on Track Rod End
Re: Steering joint
Yea twiss thr joint on the end of the z bar that connects to the steerin box arm , is it just like a track rod end or can it not be replaced , thanks
Re: Steering joint
Probably depends on your Z bar as it will most likely be home made.
Re: Steering joint
Cheers jordi i will have to have a look , if so do you know what they would have used is it a track rod joint , thanks
