ForrestHarris
Post
by ForrestHarris » Thu Sep 15, 2016 4:26 pm
Just finished replacing the front wheel bearings on my 410 this morning, but I have noticed there is excessive movement in my king pins, about 5mm movement
Just wondering whether you can purchase shim's for these, and if so anyone know where from?
If not I will make some up tonight
zook123
- SCUK Addict
Post
by zook123 » Thu Sep 15, 2016 4:33 pm
You can, but are you sure you don't just need to replace them?
http://www.jimnybits.co.uk/shop/jimny/s ... _1090.html
My Jimny needs the kingpin bearings doing, it shakes between 30 and 40, 12 and 6 Movement on the wheel, and it's now starting to leak...
Where did I leave my hammer?
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
ForrestHarris
Post
by ForrestHarris » Thu Sep 15, 2016 4:42 pm
Cheers Dean, I've removed the pins and checked them against the specs on Haynes pro and the are within tolerance. And the bearings seem good
Whoever had the vehicle before me had made up a single shim that is 3mm thick for the top and bottom pin
Hopefully a new set of shim's will remove the play.
Might replace everything though while it's all out
- The Boss
Post
by ScottieJ » Sun Sep 18, 2016 1:41 am
On sjs you remove shims to reduce the amount of play. If you are stuck and can't find any (local Suzuki dealer will have them) then I can sort you out a few.
