Why does she lean to the o/s
Rod4578
Post by Rod4578 » Tue Jun 07, 2016 10:11 pm
So my sj is finally on the road but have noticed she leans to the o/s suspension wise she has 2 inch lifted springs and astra shocks all round I bought thsee nearly new and have done approx 60 miles on them . I have thought about swapping the rears round side to side . What ar everyone's thought on this ?????
SherwoodNash
Re: Why does she lean to the o/s
Post by SherwoodNash » Tue Jun 07, 2016 10:53 pm
Quite common!
Lot's of weight that side, driver, main dash, battery, steering system, fuel tank, driver, diffs etc
Here's a thread you may like, make sure not to be drinking coffee when you get to andyrew's post :D
http://forum.suzukiclubuk.co.uk/vi ... 15&t=10167
zook123
Post by zook123 » Wed Jun 08, 2016 8:18 am
The Famous Suzuki Lean.
On the Jimny's they actually sell a kit to sort this out, it's a 1" rubber spacer that fits in the Coil Springs.
I would suggest a counter-weight, such as move your tools onto the left!
2002 Jimny O2 Ragtop
Wessex 4X4 Reponse - WE411
wessex4x4response.org.uk
Rod4578
Post by Rod4578 » Wed Jun 08, 2016 8:19 pm
Ahhhhhhhh yes the great suzuki lean going to stick bag of cement on the other side see if it helps it is settling down the more I use it aswell
bazza413
Post by bazza413 » Tue Jun 14, 2016 8:23 pm
Had exactly the same on mine, swapped springs, checked mountings pulled my hair out.
In the end I made 1 extended shackle for the o/s/r spring and hey presto no more annoying lean.
