Hi all
New to the suzuki world, have just bought a samurai that has stood in a barn for 10 years and need some help sourcing some parts.
Master cylinder
Handbrake cables
After cat lambda sensor
Hope some one can help
Kerry
Hi all
Re: Hi all
Hi
to
sure someone will have most of that
Re: Hi all
Master cylinder
Handbrake cable
Are you certain you have a Samurai, not a 413?
I have an SJ50V SJ413VX non-samurai, it's got a transfer case drum handbrake instead of the rear wheel drum handbrakes on Samurai's. The cable will be different and your master cylinder might be different if you have a 413, not a Samurai.
Re: Hi all
there are a number of different handbrake options and I wouldn't count on a certain model having a certain type fitted as they can be mix and match, on my samurai it has a cable to each rear drum,Anton wrote:
Master cylinder
Handbrake cable
Only one side was available from my local motor factor so I bought x2 and reversed the clips on one to hand it for the other side,
Re: Hi all
And how many parts have been changed over the yearsTramp wrote:there are a number of different handbrake options and I wouldn't count on a certain model having a certain type fitted as they can be mix and match, on my samurai it has a cable to each rear drum,Anton wrote:
Master cylinder
Handbrake cable
Re: Hi all
Exactly my point. You have to be sure you're getting the right parts!Tramp wrote:there are a number of different handbrake options and I wouldn't count on a certain model having a certain type fitted as they can be mix and match, on my samurai it has a cable to each rear drum
Also, turns out that the link to brakes international has the word "jėėp" in it, which naturally got changed to something else, so the links I posted don't work...
Re: Hi all
From the fact she is after handbrake cable(S) and a lambda sensor i'd say its for a 1994/1995 spanish samurai with injection
Suzuki can usually get the handbrake cables but they are about £65 each. You can also use jimny handbrake cables which are cheaper, but the brackets are slightly different and require a bit of adjustment
Re: Hi all
You won't have an after-cat lambda sensor, EFI and some carb models have a pre-cat sensor
