Power steering
Seth
Power steering
Post by Seth » Tue Dec 15, 2015 3:21 pm
I'm going to be fitting power steering to my Sammy, I'll be using a Jimny steering box, but as the Sammy is a G13B engine, I'm guessing that the whole early Jimny set up will be a pretty straight forward fit and simpler than converting Vit pipes, or are they pretty much the same, I've already done the double pulley, so ready to go.
I'll also be fitting high steer at the same time, SPOA and RUF, has this caused anyone any problems.
Jazza
Re: Power steering
Post by Jazza » Tue Jan 26, 2016 4:06 pm
I am looking to do similar to my 1995 sammy but a bit unsure on were to start!
How did you get on? Have you got any pics?
Re: Power steering
Post by dan_2k_uk » Tue Jan 26, 2016 11:07 pm
The high steer won't cause any problems with running PS.
I'm not too familiar with fitting it to a G13 as it was just a bonus of fitting my G16 when I converted but if the holes are there I would just go for a Vitara pump as that's what's commonly used.
The pipework can be easily shortened with a hydraulic grade pipe coupling and putting a little twist in it with a bit of heat applied.
Re: Power steering
Post by dan_2k_uk » Tue Jan 26, 2016 11:27 pm
Theres a little bit iny build thread here where you can see if you have the correct mounting holes for a Vit pump etc.
http://forum.suzukiclubuk.co.uk/vi ... &start=130
Seth
Re: Power steering
Post by Seth » Sun Feb 07, 2016 8:43 am
That's a very nice write up
dazerede
Re: Power steering
Post by dazerede » Sat Jul 02, 2016 10:15 pm
Thanks Dan for the write up just fitted my power steering pump just got to do the steering box naw
4” calmini lift kit :)
