sj410 gearbox dilemma
Posted: Sat Nov 14, 2015 4:25 pm
I have these 2 gearboxes. The small one is the original early (1982/83) gearbox and the larger one the original later model. Both will somehow fit to the engine (with some modification) and both are with 4 gears. My intention is to keep it as original as possible but the larger gearbox seems more robust . Can you give me your advise on what you think I should do.
p.s. I'm worried that since the small gearbox they had a factory problem, since it was in use for just 2 years.
thanks
thanks
