Page 1 of 2
electric fuel pumps
Posted: Thu Apr 02, 2015 10:01 pm
by andyrew
Hey dudes
I've got to purchase an electric pump to feed the weber
For the vit conversion. Can anyone recommend
A brand they've had good experience with?
Any too avoid?
Re: electric fuel pumps
Posted: Thu Apr 02, 2015 10:03 pm
by dan_2k_uk
I borrowed Scotties truck a few weekends ago. Dont use whatever he uses. Too loud.
Posted: Thu Apr 02, 2015 10:28 pm
dan_2k_uk wrote:I borrowed Scotties truck a few weekends ago. Dont use whatever he uses. Too loud.
It is solid mounted and right behind the driver seat in the back
that doesn't help! Need to get some isolated rubber mounts for it, that will quieten it down.
Posted: Fri Apr 03, 2015 5:06 am
by daemon982
This is what i use to feed vitara carb, it works great. You don't even hear it. I have it mounted in engine bay.
http://www.kraftstoffpumpen.com/benzinp ... -c-25.html
Posted: Fri Apr 03, 2015 11:10 am
by kibris
I use one of these
Click Here for Ebay Listing
designed to suck so can be mounted under bonnet - works well - lot quieter than the facet.
Posted: Fri Apr 03, 2015 3:30 pm
I've got a facet pump Andy. Now mounted on a rubber bush.
Posted: Fri Apr 03, 2015 6:58 pm
by andyrew
im guesing the fuel return just gets blanked off?
Posted: Fri Apr 03, 2015 8:43 pm
andyrew wrote:im guesing the fuel return just gets blanked off?
There won't be a fuel return. The webber doesn't have one, just fuel in. The fuel return is off the pump on the propper carb'd 1.3 and 1.6s.
Posted: Sat Apr 04, 2015 5:59 am
Ive got one of the black plastic facet pumps and haven't had any problems with it...
Its really loud clicking when it runs out of fuel!
Posted: Sat Apr 04, 2015 9:01 pm
by Anton
I bought a generic thing from my local factors. It makes a horrible noise because it's hard mounted to the inside of the chassis just forward of the tank - I really need to mount it using rubber mounts (ala t-case mounts) instead.
