Funny noise when driving
Sirocksdude
Post by Sirocksdude » Mon Mar 02, 2015 1:05 pm
So I'm a bit of a cabbage when it comes to mechanics so need some help please. When im driving there is a noise that sounds quite similar to jingling coins, sounds like it's coming from under front end. Any ideas what it could be. Sammy seems to be running sweet but if it's anything that could get worse would rather sort now. Thanks
timwilks13
SCUK Website Padawan
Re: Funny noise when driving
Post by timwilks13 » Mon Mar 02, 2015 1:27 pm
Is there any wobbling or vibrations when driving? or is it just a noise?
Have you checked your pockets for loose change?
Post by ScottieJ » Mon Mar 02, 2015 1:33 pm
:hahaha: :hahaha:
Check all the prop UJs underneath and for anything that could be loose, exhaust mounts/joints etc.
Post by Jordi » Mon Mar 02, 2015 1:41 pm
Collar on the diff housing?
timwilks13
Post by timwilks13 » Mon Mar 02, 2015 1:43 pm
Was just about to say that Jordi, mine used to rattle around, then it go bashed around a bit and tightened itself up.
Could be the flywheel bolts, they make a funny rattling sound when not done up tight enough! (or so I hear)
Post by Anton » Mon Mar 02, 2015 6:45 pm
My front propshaft made a noise a bit like loose change when the UJ got worn. New UJ and it was fine - the rear made a clicking sound before I changed it, so I think they can make a variety of noises depending on just how they're dying.
Grab your front propshaft and give it a wiggle, if it's sloppy then that's likely to be the culprit.
Sirocksdude
Post by Sirocksdude » Tue Mar 03, 2015 9:24 am
Thanks everyone, will have a gander and see what I find. For some reason I reckon it could be front prop as mentioned had one fitted a while back and the mechanic that did it was a bit of a joke
1995 Zuk
Post by 1995 Zuk » Tue Mar 03, 2015 3:01 pm
try removing the wife/gf/ mother inlaw from under the car, they like to be inside sometimes.
2003 GV1600 sport
1995 Vitara SWB
