Page 1 of 2
Diff guards
Posted: Sun Jan 04, 2015 11:26 pm
by Josh-holden
Where can i get some weld on diff guards from?
Re: Diff guards
Posted: Mon Jan 05, 2015 1:40 am
by donkeychomp
Firstly that's a very bad idea...why would you weld them on? You'll need to take them off to access other areas. And it isn't rocket science. Measure up and cut some steel and bolt them on.
Re: Diff guards
Posted: Mon Jan 05, 2015 9:01 am
Mine are welded on. They are made using 8" steel pipe caps
Re: Diff guards
Posted: Mon Jan 05, 2015 12:36 pm
by Ladaman
ScottieJ wrote:Mine are welded on. They are made using 8" steel pipe caps
I like that idea. I was wondering what to use on mine, as I've "dinked" them, and don't want them to get worse.
There might be a chat with a local fabricator this afternoon.
Re: Diff guards
Posted: Mon Jan 05, 2015 2:00 pm
by Josh-holden
The reason I want to weld them on is because iv heard that bolt on ones bend easier.
Re: Diff guards
Posted: Mon Jan 05, 2015 3:12 pm
You only need to protect the diff pan anyway so welding it on won't cause any issues. I would add bigger drains than the ones on mine though, it's a nightmare to get all the mud out with only a small drain hole
Re: Diff guards
Posted: Mon Jan 05, 2015 5:02 pm
by donkeychomp
Mine's bolt on for that reason...all the crud that collects in there is just going to cause rust issues and less you can take it off and clean everything!
Re: Diff guards
Posted: Mon Jan 05, 2015 5:18 pm
I just hose mine out when I clean the rest of the vehicle
Re: Diff guards
Posted: Mon Jan 05, 2015 5:32 pm
by Anton
Scottie - how much were the pipe caps?
Re: Diff guards
Posted: Mon Jan 05, 2015 5:53 pm
by mattmiles
Its a real shame Rob no longer makes these. Have a pair on mine, work a treat.
Matt
